It is currently Fri Jul 25, 2025 10:35 pm
PostPosted: Fri Jun 03, 2005 3:57 am
When mixing a 2-part epoxy, what happens if you don't put enough hardener in? Will the result be a slower curing epoxy (ie, more work time), will the epoxy just not harden properly at all, or will it be weaker? Any idea?
Thanks!
PostPosted: Fri Jun 03, 2005 4:05 am
[QUOTE=John Elshaw] When mixing a 2-part epoxy, what happens if you don't put enough hardener in? Will the result be a slower curing epoxy (ie, more work time), will the epoxy just not harden properly at all, or will it be weaker? Any idea?
Thanks!
John[/QUOTE]
Softer and weaker tensile and sheer strength. Put to much and it is more brittelMichaelP38506.5474189815
PostPosted: Fri Jun 03, 2005 4:16 am
Depending on how short you were on the hardener the epoxy will cure but a bit softer. if you were more than 20% short the epoxy may not cure to a hard film but rather be a jell. firm to the touch but some what plyable. More than 30% short it may not cure. It is better to thin by means of a solvent that will gas off to thin and extend pot life.MichaelP38506.5559606481
